Old 04-25-2022, 05:38 PM   #2
ike84
Originally Posted by Dana View Post
If the smoke is by your valve covers, chances are that your raw water pump, not your engine water pump, has a destroyed impeller and that’s why it over heated. The small rubber pieces can get in the system and possibly make noise. THere is also metal flappers that keep water from flowing back into the engine that could be making that clatter as there wasn’t any water in them. If you have a closed cooling system (heat exchanger) this is less likely the problem. Could be an easy fix. Good luck!
Yes, it is an open cooling system and I was referring to the sea water pump. I didn't know about those flappers, that would make sense too. I ordered a new impeller last night and will tear it down when I get a bit of time. Planned on back flushing the system too to try to get rid of any pieces lodged downstream. Thanks for the help!
Sent from my SM-G970U1 using Tapatalk
