Old 04-25-2022, 07:23 AM   #16
rastta
rastta's Avatar
Originally Posted by Quadcammer View Post
I wouldn't use blue. From my understanding, under high heat during track use, it can actually turn into a lubricant that could make them loosen up.
Use RED loctite.
Removing them will be a pain (remove rotor, heat hub with torch), but you don't want them coming loose on track.
Exactly. Use a high temp Loctite. Color is irrelevant. Type is more important.
This "blue" is good for 650 degrees.
https://www.lawsonproducts.com/Loctite/2422-Ultra-High-Temperature-Threadlocker-Blue/1383606.lp
This red is good for 450 degrees.
https://www.amazon.com/Loctite-492143-Temperature-Threadlocker-36-Milliliter/dp/B0002KKTR2
rastta is offline   Reply With Quote
