Old 04-24-2022, 12:44 PM   #10
Paul Lohman
There are not two procedures, there are two stages; for the flywheel bolts (new only, do not reuse), torque to 19 ft lb, then tighten another 120 degrees of rotation to gain the correct bolt stretch. For the pressure plate, torque to 17 ft lb.
Is 17 ft lb correct for the clutch pressure plate. Installing soon. Thanks.
2001 Boxster S
Paul Lohman is offline   Reply With Quote
