Old 04-16-2022, 02:10 AM   #8
Smallblock454
For a 1999 engine you'll need a 7.0 DME.
A 1997 986 will have a 5.1 DME - not compatible, because it hasn't the correct in- and outputs. Also the engine wiring harness is different.
If you get an 7.0 DME from a 986 the mapping needs to be flashed for a 996 3.4 engine. This can't be done by OBD. This always needs to be done on the bench.
Check what alarm control module you have. If you have a M531, you'll need to update to an M535. If you have a M535 it can be reprogrammed to work with the newer DME.
If you need to update from M531 to M535 the wiring harness has to be updated too.
Smallblock454 is online now   Reply With Quote
