Old 04-12-2022, 12:15 PM   #1
gumetina
DME You got ...604 , is the same i have. It lacks downstream CAT O2 sensors, SAI pumpm, and maybe something else too...
It is tunable for sure, You can flash it by obd2 plug (partial 16kb) or on the bench (pins) full flash.
I have Yet to test if it will start with 3.4 file flashed in 2.5 ecu. I guess, even if it does , it will complain about the things it misses.
Since the injectors are the same on both engines, i suggest You skip on buying 3.4 ecu for now... There are probably folks around who can make anything You might need for the 3.4 later,,,,
gumetina is offline   Reply With Quote
