Old 04-11-2022, 08:03 AM   #10
gsy4771
Originally Posted by Dave80GTSi View Post
I'll assume that this is directed to me, since I posted the pictures?
If so, then yes, I've been very pleased with the stock non-cat manifolds and the Circuit Werks "resonators". Aside from the fact that all of the white insulation which was a part of the "resonator" portion of the Circuit Werks pipes was blown out after about the first 10 minutes of use, ending up in the muffler!
Fortunately I was able to fish out most of this insulation after removing the muffler - what I could not remove eventually blew out of the muffler's tips.
One difference between the older pictures that I posted and the car as it sits today is that I ceramic coated the manifolds, as you can see below:
The use of the non-cat OEM manifolds resulted in a notable performance boost as compared to the cat manifolds as shown in the second picture in Post no. 23, so I am well pleased.
DM
Thank you for the response. How you had issues with the car passing inspection? You do not have any cats with your setup? Also any warning lights?
gsy4771 is offline   Reply With Quote
