Old 04-10-2022, 02:45 PM   #28
elgyqc
elgyqc's Avatar
Originally Posted by BrokenLinkage View Post
Seems I recall the bolts at the triangular plate are splined at the base and pressed in, so inspect yours and if this applies, turn the nut not the bolt.
Pretty sure I replaced with normal non-splined bolts. Was a while back.
You are right about the splined bolts. They can be cut off with a Sawzall or hacksaw if you have lots of time. When I do muffler work I only take the saw under the car with me... I replaced with stainless steel bolts and nuts.
Grant
elgyqc is offline   Reply With Quote
