Old 11-05-2006, 08:28 PM   #14
MNBoxster
Originally Posted by blue2000s
The fuel is primarily sprayed onto the intake valve not to cool it, but to enhance the atomization of the fuel. It is a side benefit that the heat from the valve is carried away by the air/fuel. The valve is also cooled by the air/fuel rushing past it on the intake stroke. FSI engines show that the intake valve can opperate just fine without spraying fuel on them.
Typically, it's the exhaust valve that has the cooling problems as the hot gasses of combustion run past it and the valve's size is somewhat smaller than the intake. This is why you'll find sodium filling in exhaust valves and not on the intake side.
Hi,
I actually meant the AF mix, guess I oversimplified. I know the Boxster has Sodium-filled Exhaust Valves, so does my Esprit...
Happy Motoring!... Jim'99
