Old 04-04-2022, 03:05 PM   #20
magno_grail
Alright, but the connectors have a snap lock you can hear click when full seated.
Irridium plugs last longer than the cheaper ones. As long as they are the right heat range and gap the new plugs should not be causing the misfire.
Bought a new starter without finding out what the noise is from? PMGR Starter usually have a plain bush on the gearbox side and needle on the ring gear side of the output shaft. The grease in the gearbox or needle could have dried out. The armature end of the motor is commonly a bush also.
If it sounds as though the Bendix is not engaging it might need a new solenoid, about $20 from a starter supply.
magno_grail is offline   Reply With Quote
