Old 04-04-2022, 02:47 PM   #13
elgyqc
elgyqc's Avatar
Originally Posted by magno_grail View Post
Unless they changed from 1999, the coils are mounted on the plugs. There are no plug wires and you cannot pull back any rubber boot to see if they are seated...
I was talking about the coil wires not plug wires. There is a rubber boot over the connector that plugs into the coil and it is easy to think the connector is on all the way when it is not, hence the suggestion to pull the boot back.
Grant
