Thread: Help with code
Old 03-30-2022, 03:42 PM   #2
JFP in PA
Originally Posted by gman1113 View Post
Year is 2000
Boxster S 98k miles
OK, P1117 is the code for a heater failure on the O2 sensor ahead of the cat on bank #1. Diagnostics are to check the heat circuit on that sensor for resistance (should be 1.8- 2.5 ohm), a short to ground, or no voltage. If everything is OK, replace the sensor.
