Old 03-24-2022, 03:06 PM   #4
gumetina
Did not get the manifold how i wanted, but the only way i could. Thats why the thing is probably going to get a turbo, since its cheaper to build boost then to find a RS4 intake (big port) manifold.
It is taking some time....
I guess i made a mistake with engine choice looks like the 2.7tt fits more easy then anything, but i could not live with the 1.8t
A lot of smaller things to sort, trans oil cooler is in the way of exhaust, throttle cable is short, coolant hoses are just a bit short , fuel rail needs rewelding etc.
I did however modify the stock ecu to run VAG COP active coils and it was pretty straight forward job, just to see it fire and i will post on how to do it.
I will also test if stock ecu hardware runs with 996 3.4 software (bigger maf, mapping for 300hp etc)
Cheers
gumetina is offline   Reply With Quote
