Old 03-22-2022, 08:47 AM   #1
FoFoJoe
FoFoJoe
FoFoJoe's Avatar
I had my water pump replaced at around 119k miles and at the time I had the pump, gasket and coolant replaced. I have a spare expansion tank for when mine goes kaput, but the system was pressure tested and the old tank is still holding just fine.
I can't remember if I had the thermostat replaced.. but if it wasn't the current one is around 5 years old.
Mike out of curiosity what are the symptoms that led to you replacing the water pump? Mine got a small leak on the surface where the pump mounts and was dripping pretty bad. I only noticed when my overheating/coolant light on the dash was blinking on a cold start. Then I saw the puddle..
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
