Old 03-18-2022, 06:46 PM   #4
78F350
Motorist & Coffee Drinker
78F350's Avatar
From the Sacred Manual, Chapter 57-22, pg 3: Thou shalt undo fastening screw -1-, set the contour in relation to the wing and side member by shifting the angle pieces -3- in their vertical and horizontal positions. [See body gap dimensions]
The settings can be extended by removing the centering sleeve -2-.
Bolt Torque, 23 Nm (17 ft).
Gap specs:
A - 5 +1 mm
B - 1.6 +-1 mm
C - 4.4 +1 -0.5 mm
D - 4 +1 -0.5 mm
