Old 03-17-2022, 08:08 PM   #13
howdy
Originally Posted by elgyqc View Post
I love IMSB discussions!
I plan to reuse the old spring clip. For the installation I was thinking of using a metal collar (that I have already made from a piece of exhaust pipe) held in place by a tie wrap that will hold the spring down and the collar will slide back as the bearing is inserted.
I am also pondering using a "pusher" rather than a hammer to install the bearing. I think a frame could be made that attaches to the block and then permits a threaded rod to slowly push the bearing into place. Doing this would allow one person to do it, pausing the operation to work the clip into place. I am on vacation so have not worked out the details of how this would work.
I made a tool to remove the wheel hubs with a puller rather than a slide hammer when I changed all my wheel bearings. A puller or pusher is much less agressive than a hammer.
Without the right tool it's almost like needing a second set of hands. If you can come up with a tool to replicate a second person that would do the trick. Or something that works like a ring compressor when installing pistons in an engine.
howdy is offline   Reply With Quote
