Originally Posted by Most_Wanted
Anyone know if the koni special active pairs well with vogtland springs (30mm drop)?
My concern is the shock might be underdamped causing bottoming out/tire scrubbing during hard cornering.
If you're talking about the Vogtland sport springs, I don't know, the drop is almost the same as the H&R sport springs. Mine dosen't bottom out or scrub at all, and I'm running 25mm spacers at the front and 20mm rear. I did a couple of track days in 2020 and I had no problems with rubbing at all. Here's a couple of pictures so you have an idea of how low mine is.
