Old 03-07-2022, 01:43 PM   #1
Laredo
The battery is in good condition, tested with load.
The alternator doesn’t generated any code or light. No further test.
The problem is only with the low RPM when I stop, this deep is only one second. And after that the rpm are estable in 750 - 800 rpm. Everything else looks fine.
The failure in voltage has correlation with the low RPM
Laredo is offline   Reply With Quote
