Old 03-01-2022, 08:26 PM   #2
pilot4fn
Originally Posted by robdelorenzo View Post
Good thread. The issue that I am having is the “Kerchunk” when I pull out the key happens maybe 50% of the time without some help. Is this a problem with the mechanical key assembly or the $10.00 switch? Or both? Knowing these cars, I will guess that it’s not the $10.00 switch. I appreciate the clarity.
Same kind issue - difficulty on removing the key - has been discussed here or UK's Boxa -forum and the reason has been the ignition switch. Yes, in some cases the key barrel / lock assembly.
Also in my car the key operation eased up as I did change the switch (to a new Audi part). I'd start with that to find a cure.
Boxster 2.7 2001 Manual
pilot4fn is online now   Reply With Quote
