Old 02-25-2022, 01:41 PM   #26
OldManMo
The cams also had a thick (well less than 0.01mm) build up. Took a while and again by hand, though I did use a fine glass beads on shaft between the bearings and cams but they cam up nice
lifter carrier also came up nice though this had a lot of deposits at the bottom of the ultrasonic bath when cleaned. Still needs a little more work and polishing
OldManMo is offline   Reply With Quote
