Old 02-20-2022, 07:22 AM   #4
JFP in PA
Unless there's a difference between the 98 and 00 braking systems... why do you need the Durametric?
I changed the brake fluid in my 98. No big. No software. Just in and out.
Did I miss something? Is this a complicated procedure requiring the use of software?
My brakes work fine.
If you get air into the ABS control system, a simple flush will not remove it; that requires cycling the pump and valves while flushing. That is where the software comes in.
