Old 02-19-2022, 09:10 AM   #11
JFP in PA
There is no adjustment in the MFS, all adjustments are either at the shifter cable end or at the transmission lever.
Disconnect the boden cable at the shifter and trans ends. The trans end piece has a specification of 12MM for how far the cable end should protrude into the end piece. If correct, push the trans lever into park position and snap the end piece onto the trans lever. With the inside shifter in the “P” position, engage the cable in the open shifter adjuster and close the adjuster locking device. This set the basic shifter adjustment prior to testing the MFS circuit connections.
