Thanks man, very important to have in mind, i will make sure to tell him to forget the bypass option, it just did not feel right, and in Cyprus summer time we get 40 Degrees Celcius, more like all year, so not having that, i am sure will lead to overheating issues later.
I will tell him also to look into what you said, since he will start diagnosis by tomorrow, he said he does not believe its a cracked cylinder, he said also he has experience because he took apart several 986, and 911 engines - so lets see.
BTW, from the diagnosis report i sent, any indication you see, that can help determine this, or it is not detected through that.
Also, any idea about this if someone can help, its the electric issue i have, any help would be appreciated, and thanks for your time:
6 Fault(s) Present
1 Door(s) secured and terminal 15 on
44 Driver-side release stuck
61 Central locking limit position Unlocked not reached
60 Central locking limit position Lock not reached
47 Central locking synchronization
43 Passenger-side release stuck
PART NUMBER(S): 99661821901
this community - is really great - it helps a lot and appreciate any input.
Best Regards,
Chris Abou-Chabké
www.blackhatethicalhacking.com
Boxster 2.7 2002 with Bose Proud Owner
