Old 01-25-2022, 11:02 AM   #12
elgyqc
elgyqc's Avatar
Originally Posted by rfuerst911sc View Post
Interesting comment about the passenger side fitting tighter . Because the driver's side is generally used much more than the passenger side I wonder if the foam was less compressed on the passenger side ?
I was wondering if maybe a thin layer ( 1/2 " ) of additional foam on the driver's side may have helped with a tighter fit . Common sense says it would have helped .
I think with some seat time 😁 and some adjustments of the zip ties you will get them tighter. . I think you did a good job . Please try to update maybe in 6 months to see how they look and are holding up .
Last comment/question . What if anything did Lseat recommend for conditioning and treatment of the leather ?
As I mention somewhere there is a big piece of 1/2" foam in the package with the seat covers, It could be used as you suggest. I used a bit to patch the foam on the driver's cushion where it was worn away.
There are no instructions or recommendations with the covers, something that Lseat could improve.
Grant
