One point of clarification on PCA tech.
From the latest national minimum standard tech form:
Brake Fluid*: Sufficient brake fluid; premium fluid recommended. Brake fluid must be changed at least annually __ ** Date brake fluid was last changed: ____/____/20____
Local regions may require a brake system bleed prior to all events, this is just a minimum standard.
There is absolutely nothing wrong with bleeding your brakes before every event. It also allows you to take a look at your pads (inners can wear at a different rate sometimes) and suspension as well.
Agree on the Motive bleeder - just don't stick fluid it, use it only as a pressure source.
