If you are going to start running HPDEs regularly definitely get track pads. Pagid orange are a good track pad. I have run them on the street and they are not that noisy. That said, they are not quiet low dust street compounds.
As Burg points out it is not that hard to change pads and it is something you should learn to do. Bleeding brakes is the other thing to learn if you haven't done it. You will want to change out you brake fluid to something with a higher boiling point. ATE, Motul and SRF (what I run) all work well. Bleeding is something you will do at a minimum annually.
The oranges are a good starting point. Everyone has an opinion about what are the best pads. It largely ends up being preference. The best thing about brake pads is they wear out and if you didn't like them get new ones in a different compound or from another manufacture.
Also keep an eye on you rotors - they are consumables too. Aggressive pads with lots of metal in them wear rotors quite quickly. The pagids are relatively rotor friendly.
PCA Intermountain Region Track Chair
SPB #50
