Originally Posted by ike84
For example, if understeer is your issue, that can be fixed easily with 225 front tires. Also, disconnecting the rear sway bar will do the same.
Sent from my SM-G970U1 using Tapatalk
Disconnecting the rear sway bar will increase understeer, not reduce it.
