Old 01-12-2022, 04:54 AM   #1
trevorhp
simple solution to remove oil filter
Just fix 2 jubilee type clips (the ones with a flat worm drive) around the filter housing right at the top near the aluminium casting and tighten quite tightlly.
Tap one of the screw heads with a hammer to loosen the over tightened housing slightly then spin it off with your hand.
trevorhp is offline   Reply With Quote
