Old 01-03-2022, 07:28 AM   #1
elgyqc
elgyqc's Avatar
Originally Posted by ndfrigi View Post
more pics of how mine
The back of your insert looks great compared to mine, but I don't have the patience or skill or both to do it like that.
I hope the insert will look ok once it is installed in the seat back. I might have pulled the material a bit too tight when installing it on the hooks.
With the insert finished I moved on to the seat cushion cover which is held on to the foam with 3 lines of hooks across the cushion and 2 running the length of the cushion.
I was able to attach one row of the 3 rows of transversal hooks, but it took me over an hour, so I gave up on that for the other 2 rows and used zip ties with a plastic backing and a piece of coat hanger, adapted from how I did the insert. It took me less than 30 minutes to do the other 2 rows.
On the sides I was able to use the stock hooks except for one on the front (where the foam is thickest) and I ended up using a zip tie there also.
For the other seat I will probably replace all the hooks with zip ties. The original hooks have a tendency to pull through the foam that has lost a bit of its solidity over the years. The plastic backing strip (cut from an ice cream bucket) spreads the load over a larger area of foam.
Grant
