Old 11-04-2006, 11:32 AM   #22
xclusivecar
Originally Posted by MNBoxster
Hi,
Also, should the car ever fail on the road, and you suspect the MAF, just disconnect the electrical connector to it. This will cause a CEL (if you don't already have one), but the DME will go into 'Open Loop' and select a default MAP. Performance and mileage will suffer, but it will get you home w/o damaging the engine or emissions gear, service it ASAP. Hope this helps...
Happy Motoring!... Jim'99
You would think the computer would automatically go into "open loop mode" rather than flashing its cel and allowing you to do even more damage to your car if not careful.
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
