Old 12-18-2021, 02:28 PM   #5
piper6909
piper6909's Avatar
What Jeff said.
Most likely you have an electrical problem effecting your ECU. Either the light circuit is introducing voltage somewhere in the harness or it lost its ground and pulling it from somewhere corrupting the sensor signals going to your ECU. That's probably why your oil light came on, and the noise you hear is probably the engine out of tune. (wrong spark timing, wrong fuel mixture, etc.) If your ECU gets garbage in it'll go haywire, which is probably what's happening.
I'd start by checking your lighting circuit. Check the grounds, etc.
2010 Subaru Forester
piper6909 is online now   Reply With Quote
