Old 12-18-2021, 05:02 AM   #13
Didier
Originally Posted by Jgkram View Post
You don't have to remove the entire steering lock mechanism only the cylinder which can be removed using the paperclip as described in several threads on the forum. I had the exact same issues as described by you and performed that "surgery" several years ago. It has just now started to act sluggish in cold weather again and takes several seconds to completely shut off. When I removed my cylinder I soaked in a mild degreaser and flushed many times with some brake cleaner. It's amazing what came out. I then soaked in a lubricant for a few hours and cleaned my keys thoroughly. It was 100% improved and has lasted for the better part of two years.
I tried this but no help. The key moved freely in the cylinder and the inside of the cylinder also moved easily. I cleaned it anyway and lubricate well.
Didier is offline   Reply With Quote
