Old 11-19-2021, 09:14 PM   #1
Vza
Ok...Battery tested good ...but ....it wasn't the correct battery for the car so I dropped in a new one. Measured voltage across terminals w/ engine running and got around 10.5 volts. I assume its the alternator or voltage regulator. Will check connections and ground. Any thoughts. Thanks V
Vza is offline   Reply With Quote
