Old 11-19-2021, 06:59 AM   #14
blue62
Originally Posted by DrRobin View Post
RoW - Rest of the World?
My chassis number decodes as
WP0ZZZ98Z1U6XXXXX
W - Germany
P - Porsche
0 - Sports car
ZZZ - Europe/RoW
96...6 - 986
Z - Europe/Row
1 - 2001
U - Uusikaupunki Valmet factory (Finland), Boxster 97-2010
So strictly it is Europe/RoW, but I see that you are distinguishing between US and RoW.
Fuel Trim
The fuel in the UK changed from E5 for regular unleaded (95 RON) to E10 this summer, unfortunately for me that also coincided with the CAT and O2 sensor changes and the start of my problems. We can still get E5 premium unleaded, Shell V-Power (99 RON), I have never really used it, I did try a tank a month ago, but it made very little difference. Perhaps now it is running better, I would notice the difference.
E10
I think I have got the LTFT wrong for E10, as E10 is a higher fuel to air ratio the LTFT should be +4% not -4% as I thought in the last post. Shell say the V-power is 4% more efficient, so this ties in.
The good news for me is that my LTFT have come back up, bank 1 is now 0.0% and bank 2 is -1.5%. I somewhat agree with Stl-986, ignore the values of FT, just check it now and again, after all if it is running well, why worry?
I have learnt quite a bit about how a modern car sets it's fuel usage, it has been interesting, most of my real experience with this comes from motorbikes from the 70s and 80s, then you just looked at the plugs and fiddled with the air screw or jet on the carb.
Robin
I have never seen an automobile that ran constantly with 0% fuel trim.
There is always going to be some correction (fuel trim). To many variables to even make it possible to operate under 0% fuel trim at all times.. Things like engine condition, air mass (density) which changes with altitude, temperature, humidity. Driving style, engine load, fuel, ect,ect,ect.
14.7-1 AFR is only ideal under a very limited engine operating range.
The engine needs a rich mixture at times as well as a lean mixture at other times.
Catalytic converters need a fluctuation in AFR (fuel trim) to operate properly.
Emissions are not cleaned up with out that fluctuation in AFR's
Even in the days of carbureted engines AFR needs changed according to demand.
The only time I would start worry about fuel trim numbers is if fuel trims begin to exceed + or - 10%.
Most manufactures of the early 2000's limit is + or - 25%
The other times I look at fuel trims is to help diagnose other issues.
