Old 11-15-2021, 04:26 PM   #13
blue62
[QUOTE=DrRobin;643431]
Thanks for the MAF voltages, I will check tomorrow. If the reader won’t give voltage I can always check with a multimeter.
It does not happen often but they (MAF sensors) can meet those voltage specs. and still be faulty.
If you try cleaning the MAF only use a MAF cleaning spray. Don't touch any part except the plastic housing and air dry only. They are touchy little devils. Cleaning only works about 50% of the time.
Also if your running anything other then a stock air filter, non stock air filters are hard on MAF sensors.
