David,
You perplexed me with this thread so I had to look it up ( from wikipedia ) :
However, in order to downshift, engine revs must be increased while the gearbox is in neutral and the clutch is engaged. This requires the driver to shift into neutral, release the clutch pedal, apply throttle to bring the revs up to a suitable speed, depress the clutch again, and finally shift into gear. This operation can be very difficult to master, as it requires the driver to gauge the speed of the vehicle accurately and is often conducted as cars in front slow down.
So, how long did it take you to master this ? Sounds tricky...
Nick
