Old 11-10-2021, 11:21 AM   #1
Stl-986
1st....get the correct o2 sensors. You can get them on Amazon. Using the generic ones that crimp are known to cause issues.
Also, it helps to post the actual codes that are in the computer.
how many miles on the plugs?
What are you using to get the fuel trims? Standard obd readers are going to most likely give you the wrong pid for those and not be correct. Seen it myself using Torque. Correct ones can be seen in durametic/pwis. Fuel trims are going to be a symptom of your issue so I wouldn't bother looking at them for now, deep rabbit hole there.
With what you describe it sounds like an O2 issue and/or a vacuum leak.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
