Old 11-06-2021, 03:25 PM   #18
old911doc
Before you order your bearings, be aware that the S version uses a different bearing, and half shaft, than the standard model Box.
What a mess of a situation you had. I would think that a diligent mechanic would wiggle the hub to check for bearing play, sort of reflexively, while replacing discs and pads. That simple brake service is the first thing that instructors have novices do, well before letting a novice get hold of a spark plug socket.
And, to my mind, a Boxster is a relatively easy car to care for. Lemme tellya about a Lotus Elan…
old911doc is online now   Reply With Quote
