Old 11-04-2021, 10:49 AM   #1
agfours
2001 Boxster S - 58k Miles, New LN IMS and Clutch
2001 Porsche Boxster S, Seal Gray Metallic on Black. 58k miles, manual transmission. A/C cold. 18" Turbo Twists. Completely stock with the exception of an aftermarket exhaust which sounds amazing. No accidents, and in excellent mechanical condition. Lots of service done in the last 7k miles, receipts available, including:
- LN Engineering IMS (Jan 2021)
- RMS (Jan 2021)
- Clutch, Flywheel, Pressure plate, Throwout Bearing, all new hardware, shaft seal (Jan 2021)
- new tires (Continental Extreme Sport) 3k miles since Sept 2018
- brake rotors and pads
- brake lines
- brake fluid flush
- new battery
- oil changes every 3k with Mobil 1 Synthetic (last in Mar 2021)
- spark plugs
- oil tubes/seals
- MAF
- serpentine belt
- water pump and thermostat
- air filter
- cabin filter
- fuel filter
- AOS
- New SAI lines, valves (May 2021)
Top in great shape, raises and lowers as it should, some hazing of the rear window, and headlights. Paint is in excellent shape with only minor road nicks, wheels are straight with no rash. Missing crest on right front wheel in pictures has been replaced. PCA member/owned. No accidents, clean CarFax/AutoCheck available. Clear title in hand. Located in Austin, TX. [sold]. PPI Welcome. More pictures available upon request. PM for phone number if you care to discuss.
agfours is offline   Reply With Quote
