Old 11-03-2021, 06:22 AM   #2
blue62
Make sure your battery cable connections at the battery are clean and tight.
Check the ground cable connection at the body make sure it is clean and tight.
There is a connection in a little box next to your power steering res. make sure it is clean and tight.
Change your starter relay out for a new one. it is located in the rear trunk.
Relay panel #2 relay #7 (I think.)
You may want to change out the DME relay as well.
Relay panel #2 Relay #1
Relays have a little set of contact points in them that can burn or carbon up over time.
It is possible that that could be your issue.
Cost is around $10.00-$20.00 each and you can get them at any auto parts store.
