Old 11-02-2021, 12:03 PM   #14
JFP in PA
JFP, if you have a small air pocket can you remove it with the Airlift without having to evacuate the entire system?
Or you have to remove the entire coolant and start all over again? Thanks in advance!
The Airlift system does not come into contact with the coolant in the surge tank while evacuating the system; as such, you can apply vacuum slowly and allow the air pockets to bleed out of the system. Takes more time than simply filling it under vacuum, but most correction methods take longer than doing it right in the first place.
