Old 11-02-2021, 11:47 AM   #13
Gilles
While an atmospheric bleed can often clear the system, the correct way to get them out is to fill the system while it is under vacuum. The vacuum tool can also get air out of already manually filled systems.
JFP, if you have a small air pocket can you remove it with the Airlift without having to evacuate the entire system?
Or you have to remove the entire coolant and start all over again? Thanks in advance!
