Old 11-02-2021, 06:38 AM   #12
JFP in PA
Originally Posted by gdotcvg View Post
JFP. I appreciate you assistance. How would I clear air pockets? Drive cycles with bleed open or closed? Note: coolant level is not dropping in tank with bleed closed.
While an atmospheric bleed can often clear the system, the correct way to get them out is to fill the system while it is under vacuum. The vacuum tool can also get air out of already manually filled systems.
