Originally Posted by feedback
I'm looking to set up my rear suspension and I need to adjust the toe on the rears. I figure I may well end up with something like Tarett or SPL links for bump steer negation, but I came across these.
https://www.demonspeedmotorsports.com/Rear-Adjustable-Toe-Links-Porsche-GT3-Cup-9971-S-7TL.htm
I have a couple of spare front outer track control arms which I believe they used in the GT3 rear arms.
I cannot think of a good reason why they will not work but this is my first 986 build and I know nearly every avenue and combination of parts has probably been used by people here.
Looks nice, do we believe those are ok quality?
Also, is it really beneficial to use toe links with the "bump steer" feature om a 986?
Finally, do "we" fint the torque solution ones better than tarrets cheap ones?
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-control-arms/996-986-987-rear-t-control-arm-pr-996tlnk-detail.htm
Edit: I ment to quote the link to the Torque Solution ones!!
