Old 10-26-2021, 07:23 PM   #5
elgyqc
elgyqc's Avatar
On 986s the hand brake does not use the disk rotors... there are little drum brakes in the hubs. They can still seize up, of course, but that would not explain a problem with the rotors or the pedal going to the floor. Also if you were able to drive around normally I doubt that the hand brake was the problem... although it could have been making contact and heated up and seized.
Grant
