Old 10-26-2021, 08:53 AM   #5
Lowski
Originally Posted by Seadweller View Post
Before I go rogue, is there an easy way to access the back of the radio to put some pressure on it while removing it? I removed the CD holder, but there's no radio access with it removed. Does a lot have to be taken apart, or is there a simple, sneaky way to access it?
From the lower center console remove the leather trim piece and the carpet on one side. See picture "A" from the linked center console delete instructions on the Pelican site.
https://cdn4.pelicanparts.com/techarticles/Boxster_Tech/75-BODY-GT3_Console_Delete/images_small/Pic2.jpg
Once you do that you can get your hand to the back of the stereo to push on it while you are pulling on the removal tools. I had an aftermarket unit that wouldn't budge with the cheap removal tools. Pushing from the back saves you from prying damage on the front trim surfaces.
Lowski is offline   Reply With Quote
