You can delete the headlight washers, but to be thorough, you will have to either disconnect the power to the headlight washer pump, located on the washer reservoir, or remove the pump completely and plug the access hole in the reservoir.
In other words, your washer reservoir has two electric pumps: one for the windshield and one for the headlights. Disable or delete the headlight pump.
TO
