An underdrive pulley is also a good idea if you don't have it. It will help your power steering not get overheated on the track and not have any downside on the street. If your flexible rubber brake lines are original, upgrading them to flexible braided stainless steel ones is a good idea, and at the same time upgrading the brake fluid to higher temperature boiling point DOT 4 fluid is a good idea too. Race seats and six point harnesses hold you firmly in place so you can focus on driving instead of holding onto the steering wheel and bracing yourself for dear life in the corners.
