Old 10-09-2021, 11:55 AM   #4
husker boxster
husker boxster's Avatar
I used an EBS baffle. The kit can be purchased on Pelican. It does need a bit of modifying (at least mine and others did). Maybe EBS has improved their design, but don't button everything up without doing some test fitting first.
CSS = Cayman S Sport
I forgot to mention you should purchase an extra AOS and take it with you to the track. If you blow the one on your engine, you'll have a spare and your w/e won't be over.
Others can respond about square tire setup. For some cars it's frowned upon because it messes up PSM, but if you don't have PSM it won't be an issue.
1989 928 S4 5 spd - black
