Old 10-07-2021, 08:59 AM   #1
freddyet
Originally Posted by paulofto View Post
The one and only problem I’ve had with my A/C was a faulty expansion valve located under the cowling near the A/C fill valves. It had stuck open and would freeze up then thaw and freeze again producing conditions similar to yours.
The fix was a new valve from Rock Auto for about $30 CDN and a refill of the Freon since you need to depressurize the system to swap out the valve.
Good luck.
Thank you Paul , I replaced that valve .... and then had a refill of freon . no luck , problem persist . I appreciate ur comment . thank you .
freddyet is offline   Reply With Quote
