Old 10-05-2021, 05:38 PM   #1
blue62
Originally Posted by PLP View Post
Actually, I would like to know what to exactly measure and how to measure.
I will be renting Durametric Pro again (to finally activate cruise control) and I could run all the checks.
It would be nice if someone took the time to explain this stuff and show which exactly screens/variables should be active/measured.
As far as checking Camshaft Deviation it is simple:
Take the car for a good spirited 20-30 minute drive.
You want the engine oil good and warmed up and at a stable temp.
Hook up the Durametric and go to the actual values tab.
Click on... Camshaft deviation Bank-1
Click on Camshaft deviation Bank-2
Should bring up a graph and also number on the right hand side.
Do this at idle RPM.
Do a search here on the forum for camshaft deviation you will find plenty of screen shots.
If you have any problems figuring it out let me know.
Just noticed that you have a 2003 so I think your Vario Cam system is different. If it is the Vario Cam plus system then that system functions in a different way. So I do not know if Camshaft Deviation applys to that system. Perhaps someone here on the forum knows.
